Stochastic flakes plugin, take 2
  • Originally posted by vlado View Post
    Ok, I see your point. I'm wondering if a separate slot is needed though, perhaps some built-in noise would be enough to break the gradient?
    Using the bercon noise in this slot could be usefull.
    Gil Guminski
    cynaptek.com
    • yes im sure a built-in noise would be good. map slot always preferable/more powerful though, assuming its not much more complex to achieve.
      • ha,, i wonder what mapping you would use for the map in the hypothetical blend map slot? maybe another triplanar tex
        • Originally posted by super gnu View Post
          Object space, I guess. Nothing else makes much sense.
          • Originally posted by spyzor View Post
            Wow !
            This plugin is so great.
            Thanks Vlado (and Neil for the idea ) !
            Couldn't say it any better - thanks guys
            Jez
            3DS Max 2023.3.4 | V-Ray 6.10.08 | Phoenix FD 4.40.00 | PD Player 64 1.0.7.32 | Forest Pack Pro 8.2.2 | RailClone 6.1.3
            Windows 11 Pro 22H2 | NVidia Drivers 535.98 (Game Drivers)
            Asus X299 Sage (Bios 4001), i9-7980xe, 128Gb, 1TB m.2 OS, 2 x NVidia RTX 3090 FE
            ---- Updated 06/09/23 -------
            • Hi,
              is there any likelihood of supporting Max versions further back than 2014?
              Thanks,
              Steve
              • Originally posted by Steve_Green View Post
                Which one do you need?
                  3dsmax 2012
                  Brendan Coyle | www.brendancoyle.com
                    The offset is in local space (the shaded object space or the reference node object space), not world space. Could this explain it? Should it be world space? I was not sure.
                    Ah ok, that makes sense. Lets keep it the way it is then, I think it makes more sense to keep it in whatever space you choose. Thanks Vlado!
                    - Neil
                    • Wow Vlado! Just wanted to say thanks for making this! ...And thanks to Neil for pushing! This rocks!!
                      • seems it crashes with unhandled exception if i put a "normal bump" map in the triplanar tex.
                        however, if i put the triplanar tex in the normal bump (as i guess is correct actually) then it works as expected.
                        • Originally posted by cheerioboy View Post
                          3dsmax 2012
                          Yes please !
                          Glad to see I'm not the only one struggling to upgrade :P
                          (Sorry for my bad english)
                            2013.
                            Cheers,
                            Steve
                            • So cool this has been realized!! Well done Valdo and well done Neil Blevins.
                              Michael
                                Ok, will look into it.
