How to make it?
Realistic wood material (Diff tex+SpecTEX+NormalTEX,etc) with Nodes
hello andrey, on "glossy" node, why do you use "out intensity" to plug it into "reflect glossiness"?
is it because the map is grayscale or bw?
could you tell me the difference between all the socket "output", "color", "out transparency" and so on?
and when we use them?
oh and sorry for my english, cheers!
Reflect glossiness (gray socket) accepts only float values not color.
Yep.
Output is a default texture output; usually it's the same as "color", but a few textures allows to configure it (like coloroperations).
Out intensity is a greyscale variant of color.
Out transparency is an alpha value (if exists).
When the input is a grey socket you need to use grey output for connection.
