Realistic wood material (Diff tex+SpecTEX+NormalTEX,etc) with Nodes
  • Realistic wood material (Diff tex+SpecTEX+NormalTEX,etc) with Nodes
    How to make it?
    Well you need to connect appropriate textures to proper sockets:
    andrei.izrantcev@chaos.com
    Support Request
      hello andrey, on "glossy" node, why do you use "out intensity" to plug it into "reflect glossiness"?
      is it because the map is grayscale or bw?
      could you tell me the difference between all the socket "output", "color", "out transparency" and so on?
      and when we use them?
      oh and sorry for my english, cheers!
        Reflect glossiness (gray socket) accepts only float values not color.
        Yep.
        Output is a default texture output; usually it's the same as "color", but a few textures allows to configure it (like coloroperations).
        Out intensity is a greyscale variant of color.
        Out transparency is an alpha value (if exists).
        When the input is a grey socket you need to use grey output for connection.
        Support Request
          Just noticing the "Image File Texture" node. Nice! I notice the converter from internal Blender to nodes uses the separate bitmap buffer/ UV mapping/ bitmap texture nodes? Is it possible to convert directly into the "Image File Texture" node?
            cool, thanks for your answer, andrey!
