Substance to Vray
  • Substance to Vray
    I just gave this a go and got reasonably predictable results with the vray export option and following Darren Wallace's tutorial
    http://www.darrenwallace3d.com/2015/...-tutorial.html
    Good to know that it works more or less
      I couln't find any info, so just curious: DO they still have the 2k limit on textures?
      Software:
      Windows 7 Ultimate x64 SP1
      3ds Max 2016 SP4
      V-Ray Adv 3.60.04
      Hardware:
      Intel Core i7-4930K @ 3.40 GHz
      NVIDIA GeForce GTX 780 (4096MB RAM)
      64GB RAM
      DxDiag
        It's 4k at the minute, they plan to go to 8k.
          Ah, good to know, thanks!
          Software:
          3ds Max 2016 SP4
          V-Ray Adv 3.60.04
          Hardware:
          64GB RAM
          DxDiag
            I believe the basis of that tutorial is from here:
            http://polycount.com/discussion/1555...nold-converter
            A few important points; Make sure to set the bdrf to Microfacet GGR (GGX) and check the gamma settings for IOR and glossiness vs. diffuse and specular.
              im a bit confused about the ior map export from substance. Is it comparable to using falloff curves in reflection and glossiness maps or am i missing the point?
              Why do i feel that just as I start to get the hang of one method, something completely different comes out
              e: info@adriandenne.com
              w: www.adriandenne.com
