broken vray?
  • broken vray?
    Just downloaded the vray plugin/blender package (2.73. from chaosgroup site, first it wouldent launch and i had to do symlink to libGLEW.so.1.6 and libtiff.so.4 and then it would start.
    Then i couldent fint vray in render engine, so i went into user preferenced and tried to tick in the box but im getting errrors there too...
    traceback on line 306 mod=_import_ and on line 37 from vb import 'plugins'.
    Importerror: Cannot import name 'plugins'
    Currently have installed blender2.71 from git repository and it works without problem.
    Anyone knows why this dosent work?
    hi im using blender 2.73 with vray 1 month trial full vray standalone they told me the version from the website is no good , so dont worry its not anything you havent done .
    also a message for chaos WOULD IT REALY HURT JUST TO PUT OUT A FEW JPEG / PNG IMAGES OF BLENDER VRAY NODE SETUPS !
    i only have 2 weeks left with my trial period and cant seem to re size a simple UV map of a womans face . manually ,yes it resizes, but upon hitting render , no change !
    is lack of documentation ,or png demo node setups for blender vray a deliberate miss information to goad people into buying Maya ?
    im onto to you Chaos......GRRRR GRRRR i am trying to finish making a demo for possible paid work and your lack of info is f******g my chance up.
    vray is awsome compaired to blender cycles PLEASE HELP US BLENDER USERS A LITTLE MORE CHAOS thank you.
    ps generally on this planet when you buy or try new stuff , it comes with intstuctions
      nice rant
      There are some peculiarities with the Blender to Vray integration, and I would certainly agree there could be a bit more documentation about the workflow. Here is where you can find node documentation:
      http://docs.chaosgroup.com/display/VFBlender/Material
      Regarding UV mapping:
      I couldn't find an example of the image texture node - but basically the trick there is to use the "UVWChannel" from Blender for any mapping adjustments you make in Blender.
        oops, it should read:
        use the "UVMap" UVW channel from Blender
        (for some reason no one but administrators can edit posts on this subforum.)
