How to guess if a normal map needs gamma or not
This is a sticky topic.
  • #16
    Ah, I think both of them are true, right? Green-Top and Red-Left is actually rotated 180 degrees of Green-Bottom and Red-Right
    • #17
      Originally posted by rezvan23 View Post
      I see. So as Vizioen said above, RED needs to be illuminated from the right and GREEN needs to be illuminated from the bottom. Am I understand correctly?
      that would be “VRay format” of normal map, yes.
      I consider “flip green” pretty much a default as this is much more common.
      Marcin Piotrowski
      youtube
      • #18
        Can anyone else comment to confirm this is the correct alignment? Red = Right and Green = Bottom?
        I've been having this very same issue when testing the normals and I can't figure out which is the correct way so need confirmation on this.
        • #19
          Originally posted by francomanko View Post
          ok so just a bit confused, ive only ever had to flip the green channel depending on if its opengl or directx, i dont think anyone flips the red. Also im pretty sure every normal map ive seen, the red is as if illuminated from the right.
          I totally agree with this observation.
          What is it really like?
          Could we have an answer from Chaos?
          Windows 10 - RTX 3090 - AMD Ryzen 9 5950X - 128 Go RAM
          Sketchup PRO 24.0.594 + V-Ray 7.00.01
          3DS Max 2024.2.7 + V-Ray 6.20.06
          3DS Max 2025.3 + V-Ray 7.00.04
          Chaos Vantage 2.7
          GeForce Studio Ready Driver Version 566.14​
          • #20
            Still no answer from Chaos.
            Are we sure they read this topic?
            Chaos Vantage 2.7
            • #21
              Bumping for an answer on the red and green channels and which direction they should be facing.
              • #22
                I totally agree with you.
                I think there are many of us who want to know this information.
                But I don't think this section should be "under surveillance" by Chaos because we have been waiting for months for the answer.
                Chaos Vantage 2.7
                • #23
                  maybe start a new thread in another forum if this isn't getting eyes on it.
                  Website
                  https://mangobeard.com/
                  Behance
                  https://www.behance.net/seandunderdale
                  • #24
                    Or email support@chaosgroup.com, to start a support ticket, and refer them to a thread.
                    Set V-Ray class properties en masse with the VMC script
                    Follow me for script updates: @ollyspolys
