How to add dome light with HDR to the scene?
  • How to add dome light with HDR to the scene?
    How to add dome light with HDR to the scene? Thanks.
    Try these, my man:
    https://raw.githubusercontent.com/bd..._nodes_ibl.png
    https://raw.githubusercontent.com/bd...otate_hdri.png
    Logan
    Omnia Mutantur
    logan683@gmail.com
    Origin Genesis Pro
    -i7 4790K @ 4.5GHz
    -GeForce GTX Titan X @ +200 GPU, +300 Memory x2 non-SLI
    -32GB RAM
    -Windows 10 Professional 64-bit
      Thanks man, and what is the difference between regular usage of HDR in world environment and in dome?
        No problem, brother.
        You know, honestly, I don't know what the difference is. I use that setup I sent with the Environment mapping node because it works for me. I honestly can't remember if there was something with building it the other way or not.
        I'm gonna call it a night, but if you happen to try both and figure it out, I would love to know.
        Thank you.
        Logan
        Omnia Mutantur
        logan683@gmail.com
        Origin Genesis Pro
        -i7 4790K @ 4.5GHz
        -32GB RAM
          https://github.com/bdancer/vb30/wiki
          Meant to give you that and somehow didn't. You'll wanna make sure you keep that as a handy bookmark.
          And to answer about the difference, I wanna say the one I use (from the rotate HDRI image) works with the GPU but maybe the other didn't(?). All I use is GPU, so I do some things a little different and I am almost (pretty) sure it was something about that.
          Logan
          Omnia Mutantur
          logan683@gmail.com
          Origin Genesis Pro
          -i7 4790K @ 4.5GHz
          -32GB RAM
            @KUKLASHA.
            Check this thread:
            http://forums.chaosgroup.com/showthr...163#post708163
            Simpler and easier. Sorry for any confusion.
            Logan
            Omnia Mutantur
            logan683@gmail.com
            Origin Genesis Pro
            -i7 4790K @ 4.5GHz
            -32GB RAM
