Hello,
could you help me get rid of the noise in SSS? There is a lamp inside emitting light through the SSS material.
Blend file won't upload here, you can download it from Wetransfer: https://we.tl/EbtsRG51aq
I tried fiddling with settings in sss material and with DMC settings. I would like to keep render time below 2 minutes if possible since it's a part of a long animation. If you can get a nice render with longer time needed I'll take it.
Please don't distribute or use any part of the file.
Thank you.
Edward
Thank you.
Edward
