help needed for my rendering
  • help needed for my rendering
    hi guys...im having some serious problems with my rendering
    dont know but look at the corners and the uper wall...they sucks
    can u pleas help me in this one...?
    hmm...i forgot to tell you the rendering settings
    First bounce Second bounce
    1.0 1.0
    Hsph.Sub 90
    Interp.Samples 80
    Global photon map for secon bounce with bounces 15
    ticked convex full area estimate and Retrace Threshold 0.0
    Color mapping : HSV exponential
    dark mult : 1.2
    bright mult : 1.0
    cheers
      hi ....turn your imap bounces down to 0.7 each ....
      turn your Interp.Samples . from 80 to around 20... render that for startes and see what happens...
      Natty
      http://www.rendertime.co.uk
        it looks somehow like the geometry doesn't fit everywhere..
        but try natty's settings first.
          hi...thanx i tried ur settings natty and this is what i got
            when you decrease your mult. you have to increase your hsv-dark-mult.
            and i think, he meant the following:
            1.0 1.0
            to
            1.0 0.7
              well no ... 0.7 and 0.7 should be enough for interiors .... all depends on your lights and settings ..
              it doesnt look as if he is using any vray light...but just a direct light ... which is no good.
              Natty
                nope natty ur wrong..im using 2 vray lights in the windows
                i dont know why but the uper wall its still dark and the artifacts are still in the corner..
                can anybody tell me what to do...??
                  can u post your settings(all)and light's too??
                  or u can upload your scene somewhere.
                    well you need to force more light in there!...
                    I didnt say you wasn't using vray lights ...but it looks like you aren't .... meaning that you have no control over your lighting.
                    Natty
                      yeah, i also would like to see your settings at all, just as maxer said.
                      or upload your scene.
                      well natty, 0.7 ; 0.7 might be enough for interior shots, but as you can see - it's quite too dark, thus i suggest him to increase the first mult. i also thought of the lack of vraylights.
                      but it seems, that the vray light mult.s are MUCH too low. maybe a setting-mistake? i would try setting them each to 1.5 with no decay clicked. and then refine them.
                      but show your settings and i'll promise you find some awnsers to your questions as well.
                      ps: please adjust your displacementmap of your carpet
                        yeah post your scene.
                        Natty
                          its all about light control ... 0.7 is enough ... always has been ...
                          Natty
                            it depends on the glass strength, doesn't it? if i've got a high absorption-glass as windows, my vraylight won't pass through enough, so i need to increase the first multiplier, because this won't break up at my windows.
                            or am i totally wrong? i also use something about 0.7 - 0.8, but i think, 1.0 still makes sense in some situations.
                            • #15
                              of coures it all depends on scene to scene... but i tend to exclude the glass from the vray lights these day's ... makes life easier..
                              Natty
