vents problem
  • vents problem
    hi all, i've got a question - I have a set of vertical vents on the roof of a building, but when i render far away the vents go like this
    but when i'm zoomed in they look fine with no distortions
    like this:
    - and the shader is a standard solid colour, no textures etc..
    i've tried subdividing the surface and also extruding the top planes slightly but am a bit stuck, anyone got any suggestions?
    hi
    you may want to adjust your Dist thresh ... try 0.5.. or something like that... try to refine your sample's and increase your AA to 1.. / ..3 see if that helps..
    Natty
    http://www.rendertime.co.uk
      cheers Natty (again! ) you've got me on the right tracks, I'll start having a little play about
