Stuck in Network Rendering
  • Stuck in Network Rendering
    So I opened an older scene in 3dsmax 2016 yesterday and made some edits and then tried to render a test and no matter what I did it kept trying to use network rendering, I switched engines, even sent a test to the network renderer and then tried to go back to production but no luck, changed every option I could find but it still kept wanting to use network rendering. Anyway I finally found this little line of code below to put in to the listener and it worked awesome and just thought I would share it for anyone else that might run into this annoying problem:
    rendUseNet = false
    Cheers,
    Dave
    Cheers,
    -dave
    Oh, we had this a number of times. Thanks for the tip!
      You can just switch to 'Iterative Rendering Mode' from the Target drop down and back to Production also. That's what I do anyway :P
      Adam Trowers
        I did try that but for some reason it wasnt working this time... prob a new 'AD unintended feature' lol
        Cheers,
        -dave
          rendUseNet = false
          Cheers,
          Dave
          And I thought I was the only one in the universe that had that happened to. Thanks mate!
          PS: As a note, I open the VFB and click the little teapot and that renders on your computer, not on the network.
            In the maxscript listener enter this...
            Code:
            rendusenet = false
            Maxscript made easy....
            davewortley.wordpress.com
            Follow me here:
            facebook.com/MaxMadeEasy
            If you don't MaxScript, then have a look at my blog and learn how easy and powerful it can be.
              Dave.. You are my hero!! )
              i also had this strange bug with my 2016 and thanks to that litle line its gone!
              best regards, Daniel
              Daniel Krassnig / http://www.vistral-3d-visualisierung.de/ / Architektur Visualisierungen
