cosmos error
  • cosmos error
    Hi, may I know how can I solve this error
    SYSTEM: Production renderer is changed to V-Ray 6 Hotfix 3. Previous messages are cleared.
    Could not read/write file type: C:\Users\pc\Documents\Chaos Cosmos\Packages\Materials\Fabric\Fabric_C03_Pastel _Blue_20cm_536f7571\536f7571_Diff_2k_srgb.tx​
    Jackie Teh
    3ds Max 2023, V-Ray 7 [7.00.05 build 32980]
    AMD Ryzen 9 7950X 16-Core Processor@4.50 GHz | 64GB RAM | Nvidia RTX 4090
    Website: https://www.sporadicstudio.com
    Email: info@sporadicstudio.com
    YouTube: https://www.youtube.com/c/SporadicStudio
    Hey jackieteh can you please check if the reported path exists on your machine first? Also, is "pc" your user or somebody else's (is the machine you're working on shared)?
      Yes, the cosmos folder is in Document folder.
      the "pc" is the computer i am using
      Jackie Teh
        For your info, I have just changed the cosmos folder location my E drive
        Jackie Teh
          And do you still experience issues?
            No issue at the moment. thank you
            Jackie Teh
              Hi the same problem is back today, please help to fix it, thank you.
              Jackie Teh
                Does the reported file exist on your file system? Does your user have read permissions for it?
                  I have change the folder location to Drive E, and change the Chaos Cosmos Local permission to full control
                  Jackie Teh
                    Can you please check if the cbservice.exe process is owned by your user?
                      How to check?
                      Jackie Teh
                        1. Ctrl + Alt + Del
                        2. Open Task Manager
                        3. Select More Details
                        4. Go to Details tab
                        5. Locate cbservice.exe
                        6. See which user owns it
                          Hi, got 2 cbservice.exe, both show "pc"
                          Jackie Teh
                            I've got the same issue here.
                            When I import a new asset and I want to see the texture map I have this message :
                            Could not read/write file type: C:\Users\pepeb\Documents\Chaos Cosmos\Packages\3D_Models\Furniture\Fern_Leather_4 D_Arms_Executive_5b4655b1\Assets\5b4655b1_Leather_ Tex_3dh_srgb.tx
                            When I clear the message and open the texture again, the error does not show anymore.
                            The path exist and I can reach the .tx file.
                            I'm working on 3dsmax 2023.2.2 Update with Vray 6 Hotfix 3
                            Can someone help me?
                            Thanks
                            • #15
                              Originally posted by Pepebicho View Post
                              Thanks
                              I am using the same 3ds max and vray 6 as you, until today i still get this message, same like no solution for this issue.
                              Jackie Teh
