Broken
  • Broken
    New PC and new installs. Cosmos isn't working. When I import, it shows progress, but nothing happens.
    Bobby Parker
    www.bobby-parker.com
    e-mail: info@bobby-parker.com
    phone: 2188206812
    My current hardware setup:
    • Ryzen 9 5900x CPU
    • 128gb Vengeance RGB Pro RAM
    • NVIDIA GeForce RTX 4090 X2
    • ​Windows 11 Pro
    I tend to talk to myself on the forum these days, but it might help someone else. I moved the assets folder to a local folder, and it said I had no rights. So, I manually changed the right on the folder. Windows 11 is really bad about this. I create a folder and I have no rights to save there; lamo!
    Bobby Parker
    phone: 2188206812
    • Ryzen 9 5900x CPU
    • ​Windows 11 Pro
      Windows knows best...it's for your own good!
        I need to know what folders anything V-Ray uses. It seems that when you install V-Ray on Windows 11, it doesn't give those folders rights. Cosmos had only read rights for the local administrator, which is insane. This is probably why my Vantage never stayed installed inside of MAX.
        Bobby Parker
        phone: 2188206812
        • Ryzen 9 5900x CPU
        • ​Windows 11 Pro
          You are likely lacking admin rights, you are sure you are real admin?
          Dmitry Vinnik
          Silhouette Images Inc.
          ShowReel:
            I have tried absolutely everything. Local admin created new admin users, the default Microsoft admin (OneDrive).
            Bobby Parker
            phone: 2188206812
            • Ryzen 9 5900x CPU
            • ​Windows 11 Pro
              Here is how to enable hidden true admin for windows 10
              1. Open “Run” with [Windows] + [R].
              2. Type “cmd” and press [Ctrl] + [Shift] + [Enter].
              3. Type “net user administrator /active:yes”.
              4. The administrator account is now activated.
              For win 11 follow this article
              https://pureinfotech.com/enable-admi...0%9D%20command.
              ​However if your files are on the network then access rights may need to be managed by the domain.
              Dmitry Vinnik
              ShowReel:
                I'll give it a go, thanks!
                Bobby Parker
                phone: 2188206812
                • Ryzen 9 5900x CPU
                • ​Windows 11 Pro
