Cosmos problem
  • Cosmos problem
    Please see 2 attached.
    This just started with an update to Vray 6.2.01.
    Cosmos doesn’t see the library/path, It’s 8.1GB.
    But the assets & materials render as expected.
    I have to press “change” & reselect the Chaos Cosmos folder.
    I have made no folder/directory changes for Cosmos items.
    Rhino 7 current version.
    Thanks,
    Glenn
Name:	cosmos problem 20240104a.jpg
ID:	1198954 Click image for larger version
Name:	cosmos problem 20240104.jpg
    Hi there,
    Can you please create an issue in our ticketing system and attach your cb.log and config.json files (both located at C:\Program Files\Common Files\ChaosGroup\ChaosCosmos).
    Do you know what was the version number of Cosmos Browser & V-Ray before you upgraded to V-Ray 6.2.01?
    Can you please confirm that after you pressed "Change" and reselected the Chaos Cosmos folder the assets appeared again?
    Tsetso​
    Tsvetan Milanov
    Chaos
      tsetso
      Thanks for the fast reply.
      Yes after pressing change the assets loaded/appeared again.
      I was using Vray 6.1.3 Rhino 7, not sure what version Cosmos browser. I do update when prompted.
      I went from 6.1.3 to 6.2.1 about a week ago.
      This has been occurring randomly since then.
      Today it didn't happen (yet).
      I'll open a support ticket with all information you noted & the screen grabs.
      Glenn
