Materials fabrics twinbru do not show texture in the vray material editor
  • Materials fabrics twinbru do not show texture in the vray material editor
    Hi
    I am working in a bedroom and the textils from twinbru from chaos cosmos does not work.
    Why i cant see the texture in the material editor??
    Im using vray 5.1 sketchup 2021
    Thanks
ID:	1198520 I really liked the textures
ID:	1198521 Why i cant see the texture!!!???
    Hello luisgamino2,
    I have checked the same material (Plain White Texture 2281256 44cm) and would like to share some things to consider.
    Image in the Cosmos Browser is a rendered closeup, while in the V-Ray Asset Editor it is basically interactive render (when you change material settings it also updates the preview).
    Another more important point is that by default preview is not a closeup render. But you can change the preview type to Wall Closeup or Sphere for example. Also you can expand the preview window to make it bigger.
    In any case, on actual render you will get the desired result. If you need to make Normal Bump more prominent you can change its amount.
    Natalia Gruzdova | chaos.com
      Hi Natalia Grusdova
      I did all the things that you said and nothing works
      I dont simply know why
      Im using vray 5.1, i know materials from chaos cosmos is in 5.2, but with 5.1 they appear in the cosmos browser
      I did the interactive render, wall close up and the extension in the material editor and nothing works.
      Also i dont see any texture, nothing.
      I bought 3 beds from turbosquid and is a pity i cant use these great textures
      I did an effort buying these great assets and i cant assign shaders because these textils do not work
      I dont simply know what is going on
      Click image for larger version  Name:	20231228_094440~3.jpg Views:	0 Size:	1.78 MB ID:	1198584 As you can see here, no single texture in the texture slot.
      Thanks
