Chaos Cosmos Browser failed to load
  • Chaos Cosmos Browser failed to load
    I get the message above when I launch Cosmos
    It worked fine until this morning
    I tried upgrading to the latest version of Vray for SketchUp this morning - no improvement
    I'm attaching a screenshot of the message
    Ittai Frumkin​​​
    Hello, can you please send me as Private Message (PM) the log file? Located in `C:\Program Files\Common Files\Chaos\Cosmos`
      Thanks for the quick answer!
      I have a more serious problem. I tried to render and some itemsr disappeared which has never happened to me.
      I tried to upgrade to version 7 of Vray and what happened is that in SketchUp the Vray doesn't appear
      In short, I don't have now Vray in SketchUp I don't know how to upload it because it doesn't upload normally
      Can I have remote control from you to help?
      I can't work
        I have managed to load vray 6200 again but i still can't load cosmos . I don't understand what you mean by sending PM
          For a remote control session, please create a ticket in our support system. Our tech support team will contact you and will be able to debug the problem.​​​
            Now I dont need remote control sesssion - see what I wrote above . How to send you the log by PM ?
              PM is Private Message. It’s a feature of the forum. Send me the log as Private message (because logs may contain sensitive information)
                Is there an icon on the forum that I click on?
                How do I do this?
                (Excuse my ignorance but I haven't done this before)​
                  No worries. Just click on the message icon next to my name, below the profile picture, and it will start a new PM window.
                    I am getting this
                      Try renaming it to .txt or to archive (ZIP) it
                        I have send it as ZIP
                          I have to leave the office now.
                          I will be back in two weeks.
                          I hope you find a solution to the problem.
                          Thank you very much for your willingness to help and your patience!​
                            Thanks for the log. For some reason the last migration did not make it. The easiest fix would be to delete the cache file:
                            1. Stop Cosmos Browser from the Start Menu shortcut
                            2. Delete all files in this directory %LOCALAPPDATA%\Chaos\Cosmos\DB
                            3. Start Cosmos Browser from the Start Menu shortcut
                            Let us know if that worked.
                            • #15
                              I did exactly as instructed but unfortunately it didn't help.
