It would be great to change the default path" C:\Users\[User]\Documents\Chaos Cosmos\Packages" to own path (maybe same path as Material Library).
Change default download destination
Hi all,
Below are instructions on How to configure the Cosmos Browser asset download directory (on Windows)
As Vlado mentioned, we are working to publish a documentation article on that but we don't want to keep you waiting:
When you start downloading Cosmos Assets, these will be saved to a default local directory: C:\Users\[User]\Documents\Chaos Cosmos\Packages
You can change this directory by editing the Cosmos Browser configuration file. To do so:- Go to C:\Program Files\Common Files\ChaosGroup\ChaosCosmos
- Open the file config.json with an Editor of your choice, could be Notepad as well
- Find the part: "working_dir":"C:\\Users\\[Your User]\\Documents\\Chaos Cosmos" and replace the path with the new desired directory, while preserving the syntax. Save the changes to config.json
- Restart the installed Cosmos Browser Service (CCBService).
To do so, in Windows go to Task Manager>Services. - When the service starts again, it will create two folders under the newly specified directory: Packages and Updates.
From this moment on, Cosmos assets will be downloaded to the newly created Packages
Note: Please note that Cosmos assets downloaded previously to the default directory C:\Users\[User]\Documents\Chaos Cosmos\Packages will remain hidden from the Cosmos Browser after the new directory configuration takes effect. So, you need to delete them.
Let me know if you encounter any problems. The final document will contain details for Mac users as well.
Regards,Kalina Maneva
Product Manager
Chaos Cosmos
- Likes 1
Hi Kalina,
And to configure for a network folder?
Thx in advance..Nicolau Pais www.id3d.pt
My current hardware setup: HP Z820 32-Core Dual E5-2670 128GB RAM - NVIDIA® RTX 3060
Regards,
my network drive letter is "Y"
error message
"failed to create user work directories","error":"mkdir y:: The system cannot find the path specified.","stacktrace":"main.(*App).Start\n\tC:/gitlab/builds/xsCDsLbv/0/galaxy/content-browser/service/cmd/cbservice/main.go:245\nmain.(*cbservice).Start.func1\n\tC:/gitlab/builds/xsCDsLbv/0/galaxy/content-browser/service/cmd/cbservice/service.go:39"}
