envision startup crash
  • envision startup crash
    Hi there
    i've tried to run Envision but is always crashing
    here is a print screen and the log
    LINK with crash files - https://www.dropbox.com/t/TAHskaX9zv80oaGz
    Hi nunomatos, this seems like a memory issue. Can you please share some specifications on your gpu model and driver version?
    George Karampelas
    QA Specialist
    www.chaos.com
      Hi george_karampelas. thanks for your prompt answer
      my computer have this specifications:
      CPU - Intel(R) Core(TM) i9-9980HK CPU @ 2.40GHz 2.40 GHz
      RAM - 32gb
      GPU - Nvidia Geforce RTX 2060 (driver version 566.14)
      from what i've read in the specifications should be a GPU problem...:/ and you are right
      thanks
      best
      nuno
        RAM - 32gb
        thanks
        best
        nuno
        Your GPU should be compatible with no issues (unless if there is not enough vram on your model), are you on a laptop with NVIDIA optimus (CPU + APU)?
        George Karampelas
        QA Specialist
        www.chaos.com
          Hi george_karampelas i'm in a laptop Asuz ZenBook Pro
          where should I find if it is Nvidia optimus?
          thanks
          best
          nuno
            From what I can see and speculate your CPU has an integrated GPU Intel® UHD Graphics 630. Can you please try the following:
            - Open your NVIDIA Control Panel > 3d Settings > Manage 3d Settings and in the prefered graphics processor section set not-automatic but High performance NVIDIA processor. Then try and launch the application again. (restore your settings to automatic if it doesn't work)
            - Alternatively, if you cannot access the above menu, then navigate to your windows device manager and take note of how many display adapters are present and please get back to me.
            Lastly, you might want to make sure your windows OS is properly updated.
            George Karampelas
            QA Specialist
            www.chaos.com
              Hi george_karampelas... thanks for the help.
              I've tried both solutions and i've windows updated
              regarding windows device manager, here it goes a print screen
              thanks in advance
              best
              nuno
                I've just disable the Parsec Virtual Display adapter and now it works
                thanks for the help!!! i'lll make some tests and give you my feedback
                cheers
                nuno
                  Hi Nuno, as suspected there was an additional virtual display adapter causing the memory at launch problem, we did cover a similar issue with a different virtual display, however parsec seems to have slipped through [EC-1138], I will notify the team.
                  Thank you for the feedback!
                  George Karampelas
                  QA Specialist
                  www.chaos.com
                    Hi there
                    I have this issue too
                    Jackie Teh
                    3ds Max 2023, V-Ray 7 Hotfix 2 [7.00.08 build 00000]
                    AMD Ryzen 9 7950X 16-Core Processor@4.50 GHz | 64GB RAM | Nvidia RTX 4090
                    Website: https://www.sporadicstudio.com
                    Email: info@sporadicstudio.com
                    YouTube: https://www.youtube.com/c/SporadicStudio
                      Hi Jackie, are you still experiencing crashes? Have you checked the comments in thread to see if your case is the same?
                      George Karampelas
                      QA Specialist
                      www.chaos.com
                        After I use link vrscene file, it crash less instead of using open vrscene file, haven't try embed yet.
                        Jackie Teh
                          Hi Jackie, thanks for the update.
                          In that case it seems like there is an unhandled exception during the .vrscene open, we will have to investigate the file in order to be able to understand what is the issue.
                          George Karampelas
                          QA Specialist
                          www.chaos.com
