save selected objects as group
  • save selected objects as group
    It would be nice if you can select multiple objects and lock them together or even name them.
    So next time you select one of those elements all elements are selected
    like in the attachment i have 6 roofsails i might want to animate but when working i always want to select all 6 of them... i can lock the possition, but i cant lock there connection that would be nice too
    Dear arno_delange, hello.
    I moved this thread and the other one you opened in the right forum section.
    Colleagues will assist you there.
    For next posts, please be careful where the thread goes to speed up the process.
    Thanks in advance.
    TS
    Tsvetomira Girginova | chaos.com
    3D Support | contact us
      The point is even a bit bigger.. trying to automate some cars... but it is strange to see an empty car driving... so you want to add a person and lights to the car..
      If you could make a group out of it and connect that to a spline that would be very handy..
      or have the option in cosmos to already have cars with people and lights.
ID:	1225580 zz0.xy9eg475vuszz
        Hey arno_delange, did you try grouping the objects in the objects tree?
Name:	Screenshot 2025-01-29 110504.png
ID:	1225892Click image for larger version
        Boris Lazarov
        Software Developer, Envision
        www.chaos.com
          yes that is it... thanks...
            Click image for larger version  Name:	image.png Views:	0 Size:	452.3 KB ID:	1226120
            it looked like it would work.. .but i can't group these together.
            Made a light in Revit because it gives a bit more control.
            But it doesn't play with the cosmos elements
            work around is probably placing the cars and the people in your enscape scene and then export.... but would be nice if this worked too
              It seems that currently the objects originally created in the DCC (e.g. lights created in Revit) cannot be grouped with new objects created in Envision. I don't think this is a very common scenario, but I have reported it anyway. (EC-1682)
                Please note that grouping for referenced objects is currently unsupported, however if you wish to group imported assets with native ones then you will have to use File > Import > Embed instead of open or reference. We will be looking into considering further improvements for the referenced grouping however I am not sure if it's viable, so please stay posted.
                George Karampelas
                QA Specialist
                www.chaos.com
