unable to re-install
  • unable to re-install
    I tried to install one of the stable builds and after failing with some other error meassage, the installer now end with the following error message : ERROR: Unable to copy temporary log file for uninstallation of Chaos Player. That's on windowsm10.
    Any idea how to fix this? restarting the machine did not help.
    Hello,
    Please make sure you have removed Chaos Player installations from the programs and then go to Program files->Chaos Group and check if all Chaos Player folders are deleted.
    If this does not help please raise a ticket here: https://support.chaos.com/hc/en-us/requests/new so we can help you further.
    Aneliya Karadzhova
    Contact: https://support.chaos.com/
    Chaos
      Hi aneliya_karadzhova, thanks for the tips but I am afraid that did not work. I opened up a ticket (#21831).
        Can you try if deleting this registry key helps?
        HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\Curr entVersion\Uninstall\Chaos Player
        Just delete the entire chaos player folder from this registry entry and install it again.
        Let me know if it works, this might give me a good enough clue to know what the problem is.
        Alex Yolov
        Product Manager
        V-Ray for Maya, Chaos Player
        www.chaos.com
          yolov someone from support did a teamviwer session and fix the issue a while ago. but thanks for the tip anyways.
            Ah, alright, good to know.
            Alex Yolov
            Product Manager
            www.chaos.com
