mp4 export out of sync
  • mp4 export out of sync
    hi,
    I just noticed when doing an mp4 of save mask as sequence , it is holding the first frame for 4 frames, then it is ok, but it meant the mp4 is out of sync.
    I doubt this has happened before so i am wondering where is this coming from?
    What file format do you have as the input?
    Does the sequence play normally before exporting?
    Do you have any retime settings in place (f.e. the retime settings in the "transform" panel?)
    Does it export normally to another video format?
    Alex Yolov
    Product Manager
    V-Ray for Maya, Chaos Player
    www.chaos.com
      hi Alex,
      input is a jpg sequence, also tried with a exr sequence, rebooted pc.....no retimes in place.
      mp4 has a 4-5 frames delay, webm only 2 frame delay.
        That's odd. What version of Player are you using?
        Alex Yolov
        Product Manager
        www.chaos.com
          hi Alex,
          i am running 2.00.22
            Can you try the latest version 2.10.00, it was released about a week ago.
            https://forums.chaos.com/forum/chaos...-now-available
            Alex Yolov
            Product Manager
            www.chaos.com
              Scratch that, it seems to be related to the codec.
              Can you tell me if you're changing the "video compression" setting before exporting?
              And if you have it at less than 100, can you try setting it to 100?
              Alex Yolov
              Product Manager
              www.chaos.com
                It is not related to export, even a previously saved MP4 from outside Chaos Player is doing the same on our side as well
                  I'm not sure if I got this right, but do you mean that it's not related to Player? Or you're loading an mp4 in Player, re-saving it from player and then it's messed up?
                  Alex Yolov
                  Product Manager
                  www.chaos.com
                    Hello yolov,
                    Let me rephrase it :
                    If you open this : https://we.tl/t-sE50QFpFBx you can see that the image sequence goes from frame 1 to 30, when converted to MP4, the movie is playing from frame 1 to 30 correctly in After effects and all, while player in Chaos player, it reads 4 time the first frame, and stops at frame 26.
                    The MP4 is not converted using Chaos Player, so the issue does not come its conversion
                      Thanks, got it.
                      Alex Yolov
                      Product Manager
                      www.chaos.com
                        Yep, now I see it. Many thanks for walking me through this.
                        Logged under CP-287.
                        Alex Yolov
                        Product Manager
                        www.chaos.com
