Two requests around the View > Fit to Window (hotkey 5) option.
1) Make it 'sticky' across Player sessions. When checking footage from my lower resolution laptop each time I open frames I first get afraid that my camera framing is off and then i realize the frame is cropped and have to resize. It would be nice is there was a defaults/prefereces menu that allowed saved settings like that so it was 'always on' when opening new footage.
2) Make it modal, or 'live' or respond to further UI changes. Right now it's press the button and it sets the zoom level once and never changes it until you press the button. What would be nicer is if 'fit to window' is enabled, then any actions of resizing the Player window, would rescale the footage to match. Similarly I notice toggling the Layer Properties panel just shits the footage left/right and will crop it within the window again. I find myself often going back and double tapping 5 to get my footage reframed in the window properly anytime I make changes. Effectively I think this should be like After Effect's footage or composition viewer 'fit to window' setting, where it is dynamic.
