Chaos Vantage 2 released
  • Chaos Vantage 2 released
    Hello everyone,
    Chaos Vantage 2 has been released - it adds a ton of new features and functionality. I'll list the major ones below, and the full list can be seen here.
    • Added Scene States system for switching lights, materials, and objects variations
    • Added render elements for compositing and masks
    • Added support for light scattering fog (Volumetric fog)
    • Added support for multiple UV channels, including opacity, bump and normal maps
    • Added support for .vrscene file animated: vertices, vrmeshes, materials, texture and UV parameters, light parameters
    • Added support for animated vrmesh/abc files during Live Link
    • Added support for animated textures (image sequences) when using Live Link or loading .vrscene file
    • Added support for NVIDIA upscaling denoiser in interactive mode, requires driver 530 or newer
    • Added Intel Open Image Denoise denoiser (OIDN)
    • Added support for reservoir resampling algorithm for direct lighting (RTXDI)
    • Added Chaos Scatter
    • Added experimental support for AMD GPUs
    • Added support for statically subdivided geometry objects
    • Added support for creation of lights from inside Vantage
    • Added support for embedded vrscene nodes (VRayScene)
    • Added support for VRmat materials
    • Added object cloning functionality
    • Added support for mesh lights (improved with reservoir resampling enabled)
    • Added support for Vertex Color
    • Added support for orthographic camera
    • Added an option for saving render elements as separate .png and .jpeg images
    • Added support for repeat/offset U/V for UVWGenMaya when not using shading graphs (e.g. for bump maps)
    • Added support for Vertex snapping when moving objects
    • Added helper onscreen text for gizmo manipulators
    • Added functionality to quickly place the pivot on the object's bounding box boundaries
    • Added functionality to scale the render resolution by percentage
    • Added camera grouping functionality
    • Added rendering quality presets slider
    • Added Home Screen at startup
    • Added 'Open Scene Location' to the File menu
    • Added support for HDR displays
    • Added support for camera render resolution from .vrscene file
    • Added support for all options of the Advanced mode of the Color Correction texture from 3ds Max​
    • Added support for instanced lights via Forest pack and Railclone
    • Added support for V-Ray override material (MtlOverride)
    • Added support for animations outside the imported vrscene range
    • Added functionality for specifying the frame ranges for sequence rendering​
    • and more...
    You can find the full change log here:
    https://docs.chaos.com/x/DgihAw
    You can download the new version from here:
    https://download.chaos.com/?platform=47&product=63
    Our friends at Brick Visuals created this amazing video with Vantage and you can see it here:
    Thank you all for your support! We hope you enjoy this major release!
    The Chaos Vantage team​
    Unfortunately, there are very few tutorial videos about Chaos Vantage!
    I checked udemy, linkedin learning, but I didn't find the tutorial!
    There are only very beginner tutorials on YouTube!
    I'll teach you the skills necessary to stand out from the crowd. Whether it’s a personal passion or a business pursuit, you can learn video, photography, art, design, marketing skills and more.Step-by-step tutorials and project-based 3ds max and v-ray learning.
