Rendering panos in Vantage
  • Rendering panos in Vantage
    Is this possible? Do cameras in Vray have to be designated as spherical for this to work?
    Hi Luma3d,
    Nothing regarding V-Ray is needed. You have to set the Camera type to Spherical or Stereo Spherical in the Render setup dialog:
    Alexander
    Alexander Atanasov
    V-Ray for Unreal & Chaos Vantage QA
    Chaos
      Ok...so is there a file size limit for panos rendered out of Vantage? I just tried rendering a 8k image and it gave me a res of 1400 something.
        No, there isn't a file size or a resolution limit. You can check this thread here for a limitation when using the denoiser though:https://forums.chaos.com/forum/chaos...herical-camera
        How are you setting the resolution for the panorama? You can just set the Height resolution and the Width is calculated automatically based on the FOV X and FOV Y values.
        Alexander
        Alexander Atanasov
        Chaos
          I set it to still, 8192 x4608, no motion blur 1000 samples. Set it to spherical....saved as a png. The gpu sizes turn red and when render I get an image that is 1400 something x whatever the aspect ratio sets.
            When you switch to Spherical the resolution resets(which is somewhat unexpected, we will look into it) you have to set the Height gain to whatever value you like and the Width will update. If the Approx GPU memory turn red that means that you are close to the memory limit and may not have enough to render out that specified resolution. You can also try to disable the Denoiser option if the output has artifacts mentioned in the linked thread in my previous post.
            Alexander
            Alexander Atanasov
            Chaos
              Well that didn't work. Crashed. See attachments. There is a dump file which I can't attach here.
