my new animation with vantage
  • my new animation with vantage
    hello guys, this is my new work
    https://youtu.be/Ov1CuH1oZzs
    There are some good ideas, like the split screens, but as a general constructive critique I would suggest working on the camera moves and transitions.
    Ideally imo there needs to be a 'flow' to the piece, meaning that, for example, if camera A transitions to Camera B, then Cam B moves in a similar
    direction to Cam A to create continuity. Another example is a panning exterior shot being followed by an interior shot that picks up its motion from where the exterior
    left off, if you understand my meaning.
    So the general idea is that each shot is a continuation of the previous, rather than each being a separate shot with the same curve.
    Fade transitions as well as cuts can be used to mark points where there are distinct changes.
    I picked up much of this stuff from some great pro camera people and editors, so thanks to them for that
      thank for your comment
        Hi yones,
        Really good video, put me in a calm and happy mood, also good choice for the sounds.
        Did you use Forest Color texture for your vegetations?
        Congrats and keep up the good work.
        Cheers,
        Vladislav
        Chaos Vantage and V-Ray for Unreal Team Lead
        vladislav.vulchev@chaosgroup.com
          Thank you, Vladislav
          no, I didn't use Forest Color texture.
            HI yones,
            Very nice video! Can you please share with us what were the render settings that you used, how much time it took to render out, the hardware you used and did you had any major difficulties during the process?
            Alexander
            Alexander Atanasov
            V-Ray for Unreal & Chaos Vantage QA
            Chaos
              Thank you Alexander.Atanasov
              all setting has defaulted, just I change the sample in render dialogue from 100 to 200. each shot took 5 seconds for rendering in full HD mode. and I have RTX3090 24G.
              I really enjoy working with vantage and it's an amazing product.
                just think need more samples especially in dark areas because of some flickering
                  and these are some still images
                    and some more
                      Very cool...What were your render times per sequence and what settings did you use for your output?
