config vrscenes by extral vantage file issuse
  • config vrscenes by extral vantage file issuse
    Hi boys
    I have one problem:
    I have many vrscene files exported by 3dsmax, and all of them will be configed some parameters in posttab and rendertab by one same extral vantage file ;
    but every vrscene file has its own
    environment map. when I open .vantage file .the environment map info has been override .
    any Helps?
    If I understand correctly, you must have saved the .vantage file with a non-default environment.
    You can either resave the .vantage file, making sure the environment options are set to Mode="Texture", "<no environment file>, intensity=1
    or open the .vantage file in a text editor and delete the entries starting with "env_".
    What Vantage version are you using ? Is this a change in behavior from a previous version ?
    Greetings,
    Vladimir Nedev
      Vantage version:1.7 and 1.53
      any vrscene with environment , then "File- open scene as config only ". the environment map clear.
      my config vantage file has delete "env_image_path", Click image for larger version
        My vantage File:
        { "image_options": {
        "exposure": 0.0,
        "hilight_burn": 0.20000000,
        "apply_lut": 1,
        "lut_amount": 0.5,
        "lut_colorspace": 0
        "options": {
        "ambient_intensity": 0.0,
        "enable_lights": 1,
        "enable_light_tree": 1,
        "light_tree_even_split_coeff": 0.5,
        "light_tree_clamp_threshold": 0.10000000149011612,
        "light_tree_num_samples": 1,
        "global_light_mult": 1.0,
        "global_light_mult_color": [1.0, 1.0, 1.0],
        "use_shading_graphs": 1,
        "use_shading_graphs_glossy_and_gi": 0,
        "num_total_bounces": 15,
        "enable_gi": 1,
        "num_gi_bounces": 4,
        "enable_refl": 1,
        "enable_coat": 1,
        "num_refl_bounces": 15,
        "min_refl_glossiness": 0.0,
        "enable_refr": 1,
        "enable_transp_shadows": 1,
        "enable_clip_opacity_maps": 1,
        "num_refr_bounces": 15,
        "enable_bump": 1,
        "global_bump_mult": 1.0,
        "num_area_light_samples": 1,
        "light_rect_sampling_strategy": 0,
        "env_use_texture": 1,
        "env_color": [0.9100000262260437, 0.9559999704360962, 1.0],
        "env_intensity": 1.0,
        "env_clamp_tex_to_one": 0,
        "env_tex_rotation": 0.0,
        "env_tex_flip_hor": 0,
        "env_use_importance_sampling": 1,
        "bg_mode": 0,
        "bg_color": [0.0, 0.0, 0.0],
        "bg_mapping": 0,
        "bg_rotation": 0.0,
        "bg_fit": 0,
        "bg_intensity": 1.0,
        "bg_use_for_refr_and_mirror": 1,
        "fog_enable": 0,
        "fog_range_km": 10.0,
        "fog_height_meters": 500.0,
        "fog_start_meters": 0.0,
        "fog_max_opacity": 1.0,
        "fog_color": [0.40999465934233617, 0.6, 0.779995422293431],
        "fog_enable_2": 0,
        "fog_range_km_2": 0.5,
        "fog_height_meters_2": 100.0,
        "fog_start_meters_2": 0.0,
        "fog_max_opacity_2": 1.0,
        "fog_color_2": [0.779995422293431, 0.779995422293431, 0.779995422293431],
        "clamp_sec_intensity": 1,
        "max_sec_intensity": 20.0,
        "lc_enabled": 1,
        "lc_filter_primary_rays": 0,
        "lc_cell_size": 0.001,
        "lc_sample_limit": 1024,
        "lc_retrace_threshold": 1.0,
        "noise_threshold": 0.009999999776482582,
        "active_pixels_overlay": 0
        "additional_options": {
        "lut_path": "C:/vr2/TomRenderShare/gooksu.cube"
        "version": 1
          I think I understand, we will hopefully have a fix for this in the next release.
          Greetings,
          Vladimir Nedev
            1.71 is fine.Thanks
