Refraction Glossiness
  • Refraction Glossiness
    Hi Team,
    I know the support for Refraction gossiness is currently in To-Do List, but please can someone show me a workaround for achieving a glass material where its goes from transparent to transulent to Opaque?
    Here is a Picture of a meeting room glass that I want to achieve -
    I tried using the bump maps, it it doesnt seem to work perfectly.
    Thanks,​
    Maybe just use a gradient texture for the refraction color and have some diffuse color underneath ?
    Greetings,
    Vladimir Nedev
      Originally posted by Alokpatil View Post
      Hi Team,
      Thanks,​
      I've just done something like this for a recent project and it worked perfectly, I've created a standard glass panel with thickness, then I've added a surface on the back of the glass with a gradient inside the opacity slot.
      In real life the white paint coating of this material is very thin so it is always translucent, to get that you can use a two sided material.
      It is basically the same setup posted here plus a gradient inside the opacity slot: https://forums.chaos.com/forum/v-ray...27#post1153227
      3D Scenes, Shaders and Courses for V-ray and Corona
      NEW V-Ray 5 Metal Shader Bundle (C4D/Max): https://www.3dtutorialandbeyond.com/...ders-cinema4d/
      @3drenderandbeyond on social media @3DRnB Twitter
