Materialexport from Vray to Vantage
  • Materialexport from Vray to Vantage
    Hello
    My topic is the material export from Cinema 26/Vray 6 to Vantage 1.8.3.
    The materials are shown in the material list on the right, but are otherwise not shown on the model and the rendering ?
    The textures/materials are only rendered correctly for models from the Cosmos Browser.
    Thanks and best regards
    Rudi
    Hi Rudi,
    Can you send a sample scene to investigate?
    Alexander
    Alexander Atanasov
    V-Ray for Unreal & Chaos Vantage QA
    Chaos
      Hi Alexander,
      sorry, but I am not allowed to send files with extension vrscene. Click image for larger version
      Rudi
        Hi Rudi,
        You can also use a cloud service, like GDrive, Dropbox, etc and send the link so I can download it, or archive the scene in a .zip file and attach that in the forum.
        Alexander
        Alexander Atanasov
        Chaos
          Hi Alexander,
          thanks for the info, attached the file.
          Best regards
          Rüdiger
            Hi Rüdiger,
            I believe the issue is the UV mapping. Currently Vantage doesn't support all UV mapping options available in CInema4D, only UVW Mapping is supported. Can you please try to map a few object with UVW Mapping, instead of Plane or Cube mapping to test if it will work?
            Alexander
            Alexander Atanasov
            Chaos
              Hi Alexander !
              Now I have found time. I tried UVW mapping. Unfortunately, it doesn't always work. I have attached examples. Bump mapping (see cube 1), opacity mapping (cube 2) and displacement (cube 3) are problematic. Anyway I thank you for any hint.
              Best regards
              Rüdiger
                Hi Rüdiger,
                The problem with bump is that currently Vantage doesn't support procedural textures as input, only bitmaps. Probably the opacity problem is that you have to enable opacity rendering(the Leaf button in the top left toolbar). Also opacity doesn't use procedural textures and only bitmaps, and it renders as clip opacity, meaning only black and white values, no grays. Displacement in general is not supported so that is why it is not rendering inside Vantage.
                Alexander
                Alexander Atanasov
                Chaos
                  Hi Alexander,
                  thank you for your support and detailed explanation !
                  I hope Vantage will implement procedural textures and displacement in the future ?!
                  Best regards
                  Rüdiger​​
                    Hi Rüdiger,
                    Yes, full support for procedural textures for bump and opacity, as well as displacement is something that we implement but cannot say when it will be available. We will write back when any of them are ready for use or keep an eye on the Announcement section where we post new releases and changelogs.
                    Alexander
                    Alexander Atanasov
                    Chaos
