high memory consumption
  • high memory consumption
    My Vantage is consuming much more memory than before with today's update, is this happening to anyone else?
    If you have displacement or any type of hair system in your scene, this is expected.
    How much more memory is Vantage 2.2 using compared to the previous version ?
    Greetings,
    Vladimir Nedev
      I have a 16GB card, in the previous version it opened normally, in the new one a memory consumption error appears and the livelink doesn't even open.
      in the scene there was no displacement modifier or fur​
        Is there a way to leave displacement completely disabled ?
          in the scene there was no displacement modifier or fur​​
          Hm, are you sure about this ?
          Can you share the log or the scene with us, so we can check what's going on ?
          You can try disabling Safe GPU allocations from Edit->Preferences, which may allow the scene to be opened by spilling some of it to CPU memory.
          Click image for larger version  Name:	safe_gpu_allocations.png Views:	0 Size:	44.5 KB ID:	1196965
          Greetings,
          Vladimir Nedev
            Is there a way to leave displacement completely disabled ?​
            You can set the tessellation level to None, which will not subdivide the base mesh, only displace it.
            This takes just a bit more memory compared to previous Vantage versions.
            Click image for larger version  Name:	tess_level.png Views:	0 Size:	37.5 KB ID:	1196967
            Greetings,
            Vladimir Nedev
              New Update?
                Originally posted by Luma3d View Post
                New Update?
                Yes, you can read about it in the announcement section : https://forums.chaos.com/forum/chaos...2-2-0-released
                Greetings,
                Vladimir Nedev
                  Tessellation level set to none solved my problem
                  Thanks a lot for the help
