Difference in render output with Vantage and Vray GPU
  • Difference in render output with Vantage and Vray GPU
    Hello!
    I'm using Vantage to pre-vis animations, and Vray CPU to render the final animations.
    When I compare the Vantage and Vray renders, there is a difference in how the Filmic Tone Mapping is affecting the images, even though both are using the same settings. I'm using Hable.
    Is there a way to have consistency across both renders?
    Cheers
    Dean Punchard > Head of CGI at HUB
    Maybe there's a specific color mapping setting to use in Vray to get the same output?
      I think our filmic formulas match V-Ray. We don't support OCIO yet (WIP). Can you check the Vantage log for warnings about OCIO? Try comparing the result without OCIO (switch to sRGB) to verify.
      Nikola Goranov
      Chaos Developer
        I'm just using the old Gamma Workflow in Max, and I don't know about OCIO in Vantage.
        It appears like Vray's White Point is reducing the highlights, even if it's set to 0.
          This below is the default setting in V-Ray, as far as I know. In your case is the radio button set to "OCIO" or something else?
          Nikola Goranov
          Chaos Developer
            It's set to sRGB
              OK, in this case I don't know where the difference comes from. If you can share a simple scene that showcases the issue (here or through a support ticket) we will investigate it.
              Nikola Goranov
              Chaos Developer
                about matching VRay and Vantage:
                https://forums.chaos.com/forum/chaos...ge#post1223442
                Marcin Piotrowski
                youtube
