I need some help about the use of lens distortion. where can we get lens files for example.
How to use lens distortion
One way is to generate .lens files is through the Lens Analysis Tool. which comes with any V-Ray installation.
Originally posted by hermit.crab View PostOne way is to generate .lens files is through the Lens Analysis Tool. which comes with any V-Ray installation.
Originally posted by serdar_turanl View PostBut the generated file extension is .vrlens, and unfortunately, Vantage doesn't recognize it
Okay, it takes any maps, but UV maps work best (you could test with the example Distortion Textures here). Normal maps can be used too for creative effects.
Do you think this image is normal with this map?
I suppose so - the image seems distorted based on the map. Attaching the results from a new scene. Otherwise, Nuke can generate maps for lens distortion called ST maps, which are similar to UV maps.
Can't you share the lenses used at the launch here?
We've updated the docs page. You can download the sample ST maps from there. Make sure you click the download button and get the .exr.
So will you increase the number of these maps in the future?
