Intel vs Optix AI Denoiser
  • Intel vs Optix AI Denoiser
    Hi All,
    What exactly is the difference between the 2 types of denoisers?
    Which is recommended for animations?
    There could be differences in image quality. The speed of the denoisers and their memory usage is pretty similar.
    Currently Optix is recommended for animations because Intel does not yet support temporally stable output ("reduce flickering"), though it is expected to be added "soon". Intel may be slightly better for stills.
    Nikola Goranov
    Chaos Developer
      Thanks, so the "reduce flickering" tick box as per previous versions are now built in to the Optix denoiser.
      There's no other options to click when choosing denoisers as previously.
        No, the option is still there. It is only available for animations (Sequence mode of the render dialog) and only when Optix is selected.
        I think the original reason to have this as an option was that older versions of Optix produced softer results when it was enabled (on the other hand you would need very clean raw renders to make it work without flickering when temporal stabilization is off). I haven't checked if this is still true.
        Nikola Goranov
        Chaos Developer
          Hello, is there way to set lets say how much denoiser denoise? because in my opinion Optix by default kills many details!
            Very true, Intel denoiser with proper temporal denoising would be great.
            You can't set the amount of denoising.
              The AI denoisers don't have a "strength" setting. Which makes sense since they are not algorithmic, it's a "black box" neural net.
              Nikola Goranov
              Chaos Developer
