Render output error - not showing objects
  • Render output error - not showing objects
    Can somebody tell me why the objects in the scene keep disappearing when rendered?
    Click image for larger version  Name:	image.png Views:	0 Size:	1.45 MB ID:	1230455 Click image for larger version  Name:	Section A-A'..png Views:	0 Size:	478.6 KB ID:	1230459
    ​render settings are_
    Click image for larger version  Name:	image.png Views:	0 Size:	996.7 KB ID:	1230460Click image for larger version  Name:	image.png Views:	0 Size:	876.8 KB ID:	1230463Click image for larger version  Name:	image.png Views:	0 Size:	887.9 KB ID:	1230464
    thank you.​​​
    Your screenshot shows 2 warnings and 5 errors in the log (icons in the lower left corner of the window). Check the error messages. You're probably running out of video memory.
    Nikola Goranov
    Chaos Developer
      I've checked the errors and couldn't find one about Vram.. Want to know what else can be a problem in this render.
ID:	1230491Click image for larger version
ID:	1230494Click image for larger version
ID:	1230495Click image for larger version
            Yes, it doesn't look like any warnings or errors in the log are relevant.
            Do I understand correctly that you expect to see the image on the left, with the section, but the final render produces the render on the right instead, where it is mostly just empty sky? It seems that different camera settings are being used. Have you checked that the correct camera is selected in the render dialog? Should you be using Orthographic instead of Perspective?
            Nikola Goranov
            Chaos Developer
              Hi soomin_lee,
              As Nikola suggests if your scene camera is an Orthographic one you also need to set it to Orthographic in the Camera rollout>Camera type inside the Render setup dialog. Note that the ortho width must also match the one from the camera.
              Alexander
              Alexander Atanasov
              V-Ray for Unreal & Chaos Vantage QA
              Chaos
                aha..! I was rendering it with perspective camera mode. problem solved.
                Thanks a lot everyone!!
