Hi everyone, As usual i'm a little late to the conversation but am now keen to have a go at Vantage for this utopia competition. The concept of a real time renderering engine is exciting and i've also been using Twinmotion until now with ArchiCAD which works quite well - obviously though anything Chaos comes out with will be more ground breaking. I have an idea in mind for the architectural centerpiece, but am unable to get the rest of the scene to load in Vantage.
I have downloaded the scenes which open fine in Max2020 for me, but when I go to try and open the vrscene file in vantage It runs into a graphics card memory error. Bypassing limitations doesnt work either.
I've recently upgraded my workstation to a 10th generation i9 but skimped a little on the graphics card - only a 2060RTX. My primary work is just inhouse 3D so a good CPU is the main criteria other than handling the Max viewports.
I was still hopeful that there would be a means of working around this memory limitation for the Vantage competition? (maybe there is a minimum RTX card required?). If it's impossible no problems - I gave it a go, but wanted to check here first.
Am I missing something here? Once everything is loaded properly in max, would I then need to make a new vrscene file from that point?
By the way - also really digging these new 3DSMax indie licences which keeps me in 3D
