I have to install Vantage every time I use it because the toolbar is gone each time. I can't even create a new toolbar because the Vantage category is no longer there.
Toolbar
Toolbar
Bobby Parker
www.bobby-parker.com
e-mail: info@bobby-parker.com
phone: 2188206812
- 128gb Vengeance RGB Pro RAM
- NVIDIA GeForce RTX 4090
- Windows 11 Pro
Tags: None
I think it is MAX nonsense. It seems to be working now, but I woke up to a MAX launch error talking about MAX being corrupt, and to restore from the factory. I declined and MAX launched fine, and the toolbar is there.Bobby Parker
phone: 2188206812
- Windows 11 Pro
Again, I go to use Vantage and the toolbar is gone, nowhere to be found. How frustrating!Bobby Parker
phone: 2188206812
- Windows 11 Pro
Originally posted by glorybound View PostAgain, I go to use Vantage and the toolbar is gone, nowhere to be found. How frustrating!
Or did you try to reset Max by deleting the ENU Folder?
Hi Bobby,
That is very unfortunate that you are experiencing difficulties. What Max, V-Ray for Max and Chaos Vantage versions are you using? I think that this is a problem on 3ds Max's side and not Vantage but I need the requested info to try and reproduce it.
AlexanderAlexander Atanasov
Chaos
Hi agalar_ragimov,
Since version Chaos Vantage 1.4.0 the Live Link scripts are removed from the Vantage installation and from the Customize menu. They are automatically installed with V-Ray 5 for 3ds Max, update 1 and later. After installing the latest versions of V-Ray and Vantage, in Max you can enable(should be visible by default) the Vantage toolbar by doing what Alokpatil suggested - right-click on the toolbar area and check 'Vantage toolbar'. Can you please try it and say if it works for you?
Chaos
Originally posted by Alokpatil View Post
Did you try to right click on the black grey area a check on the Vantage toolbar? check the attached image.
Or did you try to reset Max by deleting the ENU Folder?Bobby Parker
phone: 2188206812
- Windows 11 Pro
AlexanderBobby Parker
phone: 2188206812
- Windows 11 Pro
Still happening. Every time I want to use it, I have to reinstall to get my toolbars.Bobby Parker
phone: 2188206812
- Windows 11 Pro
I am using V-Ray 5, update 2.3 (5.20.23 build 0001)Bobby Parker
phone: 2188206812
- Windows 11 Pro
