Toolbar
  • Toolbar
    I have to install Vantage every time I use it because the toolbar is gone each time. I can't even create a new toolbar because the Vantage category is no longer there.
    Bobby Parker
    www.bobby-parker.com
    e-mail: info@bobby-parker.com
    phone: 2188206812
    My current hardware setup:
    • Ryzen 9 5900x CPU
    • 128gb Vengeance RGB Pro RAM
    • NVIDIA GeForce RTX 4090
    • ​Windows 11 Pro
    Hi Bobby,
    You mean the Vantage toolbar in 3ds Max? What Max, V-Ray for Max and Chaos Vantage versions are you using?
    Alexander
    Alexander Atanasov
    Chaos
      I think it is MAX nonsense. It seems to be working now, but I woke up to a MAX launch error talking about MAX being corrupt, and to restore from the factory. I declined and MAX launched fine, and the toolbar is there.
      Bobby Parker
      phone: 2188206812
      • Ryzen 9 5900x CPU
      • ​Windows 11 Pro
        Again, I go to use Vantage and the toolbar is gone, nowhere to be found. How frustrating!
        Bobby Parker
        phone: 2188206812
        • Ryzen 9 5900x CPU
        • ​Windows 11 Pro
          Did you try to right click on the black grey area a check on the Vantage toolbar? check the attached image.
          Or did you try to reset Max by deleting the ENU Folder?
            Hi Bobby,
            That is very unfortunate that you are experiencing difficulties. What Max, V-Ray for Max and Chaos Vantage versions are you using? I think that this is a problem on 3ds Max's side and not Vantage but I need the requested info to try and reproduce it.
            Alexander
            Alexander Atanasov
            Chaos
              Hi Alexander!
              I couldn't find how to add Chaos Vantage Live Link in the menu or toolbar in 3ds max 2020 after updating Vantage from version 1.0.0 to 1.6.2
ID:	1142316Click image for larger version
ID:	1142317Click image for larger version
ID:	1142318Click image for larger version
              My solution: Moved back to version 1.0.0
              My specs: 3ds Max 2020 + Vray 5, hotfix 2
                Hi agalar_ragimov,
                Since version Chaos Vantage 1.4.0 the Live Link scripts are removed from the Vantage installation and from the Customize menu. They are automatically installed with V-Ray 5 for 3ds Max, update 1 and later. After installing the latest versions of V-Ray and Vantage, in Max you can enable(should be visible by default) the Vantage toolbar by doing what Alokpatil suggested - right-click on the toolbar area and check 'Vantage toolbar'. Can you please try it and say if it works for you?
                Alexander
                Alexander Atanasov
                Chaos
                  Yes, but nothing.
                  Bobby Parker
                  phone: 2188206812
                  • Ryzen 9 5900x CPU
                  • ​Windows 11 Pro
                    Originally posted by Alexander.Atanasov View Post
                    Hi Bobby,
                    Alexander
                    MAX 2022 and the latest Vantage
                    Bobby Parker
                    phone: 2188206812
                    • Ryzen 9 5900x CPU
                    • ​Windows 11 Pro
                      Still happening. Every time I want to use it, I have to reinstall to get my toolbars.
                      Bobby Parker
                      phone: 2188206812
                      • Ryzen 9 5900x CPU
                      • ​Windows 11 Pro
                        Hi Bobby,
                        Sorry to hear you are still having difficulties. What V-Ray version are you using(Render setup>Settings>About V-Ray)?
                        Alexander
                        Alexander Atanasov
                        Chaos
                          I am using V-Ray 5, update 2.3 (5.20.23 build 0001)
                          Bobby Parker
                          phone: 2188206812
                          • Ryzen 9 5900x CPU
                          • ​Windows 11 Pro
                            We cannot reproduce it on our end. It sounds like a MAX corruption or similar. Have you tried a clean reinstall of Max?
                            Alexander
                            Alexander Atanasov
                            Chaos
                              same problem on my side. Max 2021 with latest Vray 5 and Vantage. Every reboot the toolbar has gone, when installing Vantage freshly it is coming back. My feeling is that Vray/Max losses the connection to Vantage and than hiding the toolbar .
                              Sascha
