Emissive materials in Vray doesn't work in Chaos Vantage
  • Emissive materials in Vray doesn't work in Chaos Vantage
    Hello,
    I'm new to Chaos Vantage and I use Sketchup + Vray. My problem is when I import my Sketchup model (with Vray materials, lighting done) to Chaos Vantage, emisssive materials doesn't light? Could someone help?
    Thanks!
    Can you attach a simple scene that shows the issue ? It could be a SketchUp or a vrscene file.
    Greetings,
    Vladimir Nedev
      Hi Vladimir !
      Here it is.
      Thankyou!
        you can convert to mesh light them.
          Vantage doesn't support mesh lights currently.
          Greetings,
          Vladimir Nedev
            Hi lequang_tiep,
            Can you please try without the 'Compensate EV' option in the emissive material as Vantage currently doesn't support it.
            Alexander
            Alexander Atanasov
            V-Ray for Unreal & Chaos Vantage QA
            Chaos
              Originally posted by lequang_tiep View Post
              Hi Vladimir !
              Here it is.
              Thankyou!
              I think the issue is the "compensate EV" option - we don't support it in Vantage.
              If you disable it, the Vantage result should match V-Ray.
              Greetings,
              Vladimir Nedev
                Originally posted by Alexander.Atanasov View Post
                Hi lequang_tiep,
                Alexander
                Hi Vladimir and Alexander,
                I turned off "compensate EV" option and increase intensity, but it still doesn't work.
                Thanks for your help,
                Huyen
                  Hi Huyen,
                  Can you please disable the 'Clamp secondary rays' option in the Render tab inside Vantage(in the Advanced section) and see if that makes it better?
                  Click image for larger version  Name:	Vantage_RenderTab.png Views:	0 Size:	42.8 KB ID:	1142629
                  Alexander
                  Alexander Atanasov
                  Chaos
                    Hi Alexander,
                    It still doesn't work.
                    Thanks!
                      Hi Huyen,
                      Yes, now I see that you used the emissive as a layer in the VRayMtl. We currently do not support layering. For emissive materials to work you have to create an Emissive material instead of adding an Emissive layer
                      https://drive.google.com/uc?id=1k3-n...gDUONA8T921TaM
                      This is in addition to not supporting "Compensate EV" option and sometimes 'Clamp secondary rays' option can also reduce the lightness drastically.
                      Alexander
                      Alexander Atanasov
                      Chaos
                        Hi Huyen,
                        Alexander
                        Thank you so much! It work now!
                          You are welcome
                          We have it logged to add support for layering at some point but it is not going to come that soon.
                          Alexander
                          Alexander Atanasov
                          Chaos
                            This post saved my butt this weekend! Thanks to all who contributed.
                            Matthew Valero, ASAI
                            • #15
                              Hi Huyen,
                              Alexander
                              In V-Ray 6, it looks like using the menu entry showed in your screenshot, creates a Generic material with an Emissive layer.
                              How can we create an Emissive material? Does it still exist in V-Ray 6?
