RTX 3090 Insufficient memory
  • RTX 3090 Insufficient memory
    Hello!
    Have since the new update of Vantage 1.7
    Problems loading my vr.scenes from Cinema 4D.
    Graphics is a RTX 3090 24 GB memory!
    The GPU memory can't be too small, I sent you the file size in the attachment.
    What happens if you click "Yes" in that dialog ?
    Do you have lots of normal maps in your scene ?
    Vantage 1.7.0 now supports them and loading them means more GPU memory will be used compared to Vantage 1.6.2.
    How much memory does the scene use in Vantage 1.6.2. ?
    Greetings,
    Vladimir Nedev
      You can't look at the .vrscene file size only.
      External files like vrmeshes and textures also have to be loaded in order to render the scene.
      Greetings,
      Vladimir Nedev
        Also note that when "Safe GPU allocations" are enabled, Vantage will try to stay within its "GPU memory budget" as allowed by the operating system.
        As you start more processes that use GPU memory (e.g. C4D, a video game, etc), the "GPU memory budget" for Vantage shrinks.
        Greetings,
        Vladimir Nedev
          I have two Cards 1 for the Program c4d and the rtx 3090 only for Vantage
            If i click on yes nothing happens the window doesn't go away!
              You mean the same window shows again ? What happens if you click on 'Yes' again ?
              Greetings,
              Vladimir Nedev
                nothing the window remains!
                  In this case, before loading the scene, you can disable the option shown in this screen-shot.
                  Also, can you answer my other questions ?
                  Do you have lots of normal maps in the scene ?
                  What's the amount of memory used by the scene in Vantage 1.6.2 ?
                  Greetings,
                  Vladimir Nedev
                    Hello!
                    I installed 1.6.2 and the vr.scene doesn't open under Vantage 1.6.2 either!
                    If I click yes under Vantage 1.6.2, nothing happens and the error display remains, I can only end it with no.
                    I have activated safe GPU allocations under 1.6.2 and under 1.7 in deaktivatit.
                    Wenn I load the Scene ich becam a Error.
                    Only have a few normal maps in the drawing.
                    Why does the live link work? I can then render normally with Vantage, just not a stage like with a vr.scene.
                      I don't know, are you using the same render resolution in both cases ?
                      You might have to send us the scene for investigation.
                      Greetings,
                      Vladimir Nedev
                        Yes I have the same Render qualäti.
                        I have teste in Nvidia Treiber 472.84 and Nvidia Treiber 512.15 is the same error?
                        My Sytem is Windows 11 the neuest Version.
                        I will test it on a second project and then let you know if the error occurs there as well
                          Can you send us the scene so we can test it here ?
                          Greetings,
                          Vladimir Nedev
                            Hello, I have an old scene that I exported to a vr.scene with the old version of Cinema 4D and opened in Vantage 1.7 worked perfectly.
                            I then exorted the same scene again with the current Cinema 4D version into a vr.scene and open Tried that didn't work GPU Error!
                            I think the problem lies with the export of Cinema 4D in vr.scene!
                            • #15
                              I have send you the Scene per we Transfer.
