Both scenes are from c4d, the old scene was exported to a Vray scene with a c4d version about 4 weeks ago, the new scene was handed over with the current nightly image.
The old scene can be opened with vantage.
I only handed over the same drawing with the current c4d version, but the scene cannot be loaded in vantage?
Thanks for the scene.
Yes, there is something wrong with the exported .vrscene, it cannot be properly parsed, so the loading fails and Vantage (incorrectly) shows the "no memory" dialog.
You can go back to the version of V-Ray for C4D that works for now.
Note that nightly builds will always be more risky than official releases.
Hello I just downloaded the current version of Vray for C4D 2.3 but it doesn't work again GPU Error!
Please fix the problem for the next nightly if possible?
Thank you very much!
Hi Wohnraumdesign, this is caused by a recent change we made regarding the support for the Fusion shader. Can you confirm that you have a Fusion shader without a Base Channel in your scene? We will be fixing this soon, but you will need a new version of V-Ray for Cinema 4D.
I don't know if I have a fusion shader in the drawing but I sent you the original drawing. When can i you finally be able to render directly from C4d to Vantage
as in max?
We fixed the issue in V-Ray for Cinema 4D and the fixed version will be available in the next stable nightly build. Sorry for the caused inconvenience.
