EXR Alpha
  • EXR Alpha
    How do I render an EXR without an alpha channel? I want to keep my sky, and when I render to an EXR, I lose it. Do I need to tweak my HDRI?
    Bobby Parker
    www.bobby-parker.com
    e-mail: info@bobby-parker.com
    phone: 2188206812
    My current hardware setup:
    • Ryzen 9 5900x CPU
    • 128gb Vengeance RGB Pro RAM
    • NVIDIA GeForce RTX 4090 X2
    • ​Windows 11 Pro
    Hi Bobby,
    How are you opening your EXRs? If you are opening them in photoshop I would suggest to install exr-io plugin to load them properly. Then the alpha won't be applied to the image and instead it will be separated in a new layer.
    Alexander
    Alexander Atanasov
    V-Ray for Unreal & Chaos Vantage QA
    Chaos
      As Morne said in the other post, in AE you simply need to select the file in Project panel, then right-click/Interpret footage/main, then from there you can ignore the alpha.
      Or you can just choose to not save the alpha in the EXR save dialogue in Max; but that is of course more potentially destructive if you decide that you then need it
