Double the consumption of physical memory?
  • #16
    Also the 'update image sequence for current frame' button doesnt work.
    This button is disabled when you are in a live link, because in that case, the update is automatic.
    We will investigate and try to reproduce the issue on our side,
    but a .max scene and/or a recording of the issue might be helpful to understand it.
    Greetings,
    Vladimir Nedev
    • #17
      I have used VrayBitmap with a vraymtl and a jpeg sequence without any Japanese, Chinese, Korean, letters and then started a live link.
      Are there other non-Latin (non-ascii) characters by any chance? (It should have worked with any characters, but we will investigate why it didn't) Are there relevant errors in the debug log?
      Nikola Goranov
      Chaos Developer
      • #18
        Originally posted by Alokpatil View Post
        It Still Doesn't work for me. I have used VrayBitmap with a vraymtl and a jpeg sequence without any Japanese, Chinese, Korean, letters and then started a live link. Also the 'update image sequence for current frame' button doesnt work. Am I doing something wrong? I use Vray 6 + 3ds max 2023.
        I tried a similar setup in 3ds Max 2023 and V-Ray 6 and it seems to work as expected.
        We will need more information and/or a scene with the associated IFL and bitmaps.
        Greetings,
        Vladimir Nedev
        • #19
          Im sorry, but do vantage support udims and fur now?
          I just can't seem to trust myself
          So what chance does that leave, for anyone else?
          CG Artist
          • #20
            Hi guys,
            @q976431
            Let users of vray5 be able to use it under real-time linkage,
            The cloud system is available as long as there is a VRaySky in the vrscene or during Live link regardless if you are using V-Ray 5 or V-Ray 6
            do not hide the UI of the cloud system when using HDR
            The cloud system currently is only implemented to work with VRaySky as it is procedural. It will not work with Environment Color or Environment Texture mode, that is why the Cloud rollout is hidden. If the system is improved to work with those modes then we will not hide it.
            add a cloud camera to be visible,This allows you to simulate only cloud shadows when needed
            This I believe will not be necessary when support for Environment Color or Environment Texture mode is added for the cloud system.
            @Alokpatil
            Can you please send us the scene or a video of the setup?
            The update button is intended when not in Live Link as when moving the time slider in Max the images are updated automatically.
            paul Oblomov
            No, not yet for both. They are in the TO DO list with no time frame at the moment.
            Alexander
            Alexander Atanasov
            V-Ray for Unreal & Chaos Vantage QA
            Chaos
            • #21
              Originally posted by Alexander.Atanasov View Post
              Hi guys,
              @q976431
              @Alokpatil
              paul Oblomov
              Alexander
              Under vray5, when I link in real time, start to open the cloud system in vantage and set the parameters, if I adjust the parameters of vraysun of 3dsmax at this time, the cloud system of vantage will be reset. I guess it's because vray5 doesn't have corresponding parameters, so it can't read correctly.
              If I don't hide it, I can use it to simulate cloud shadows in HDR. I have tested it and the effect is very good, but now I have to create a circular sky for it to simulate the sky, so that the clouds are invisible and only shadows are retained.And turn off vraydome and use vraysky (because the UI is hidden, you have to use vraysky as the ambient light).
              It's good in some cases
              HDR+Cloud shadows:
              Click image for larger version  Name:	00000000001.jpg Views:	0 Size:	72.3 KB ID:	1154338
              Click image for larger version  Name:	00000000000002.jpg Views:	0 Size:	53.6 KB ID:	1154339
              • #22
                If I don't hide it, I can use it to simulate pregnancy and baby under HDR.
                I think google translate failed
                Nikola Goranov
                Chaos Developer
                • #23
                  HaHa. I have updated it later ---is (I can use it to simulate cloud shadows in HDR)
