Render TV animation
  • Render TV animation
    Can you render an animation inside a TV in vantage as is something moving or as an image sequence like the TV is playing a show?
    Thank you
    Hi frankc,
    Yes, with 1.8.0 update image sequences can be rendered inside Vantage if they are exported in the vrscene. The way animated image sequence is created depends on the host app you are using.
    Alexander
    Alexander Atanasov
    V-Ray for Unreal & Chaos Vantage QA
    Chaos
      How can I apply the image sequence? As material in vray and apply as bitmap, it will read in chaos vantage? Thank you
        Yes, but the current frame from the sequence will be shown only when rendering from Tools -> High Quality Render or when in a live link.
        If you are viewing a vrscene interactively, there is a button in the bottom right to update all image sequences for the current frame.
        Greetings,
        Vladimir Nedev
