Yes, with 1.8.0 update image sequences can be rendered inside Vantage if they are exported in the vrscene. The way animated image sequence is created depends on the host app you are using.
Yes, but the current frame from the sequence will be shown only when rendering from Tools -> High Quality Render or when in a live link.
If you are viewing a vrscene interactively, there is a button in the bottom right to update all image sequences for the current frame.
