Render an animated texture
  • Render an animated texture
    How can you render in vantage an animated texture like a TV show inside screen?
    Thank you
    Hi frankc,
    You have to use a sequence of images. if you have an mp4, for example, you have to convert it to a sequence of images that you then use as a texture but as i mentioned in the previous post(https://forums.chaos.com/forum/chaos...r-tv-animation) the way animated image sequence is used depends on the host app you are using. Which is your DCC (e.g. 3ds Max, SketchUp, etc) that you are using?
    Alexander
    Alexander Atanasov
    V-Ray for Unreal & Chaos Vantage QA
    Chaos
