Running live link with SketchUp and turning a layer on in SketchUp on seems to crash SketchUp and Vantage. Hangs up for a very long time and eventually just seems to crash.
Live Link w SketchUp Crashes
Which versions of V-Ray for SketchUp and Vantage are you using ?
Greetings,
Vladimir Nedev
VRay for SketchUp 6.00.01 and Vantage 1.8.4 After some further testing it just seems that turning layers on/off or working within groups while Vantage is running causes both programs to freeze for a while, but if I stay patient they will eventually unfreeze. The lockup takes a minute or two, so I don't know if this is normal behavior or if the response time should be... well... real time or not.
Matthew Valero, ASAI
Can you test the same workflow with V-Ray CPU/ GPU ?
If they exhibit a similar slow down, then it must be related to a slow down in the V-Ray for SketchUp export code and you will have to report it to the V-Ray for SketchUp team.
Greetings,
Vladimir Nedev
Can you send a scene that exhibits this behavior to support and link them this forum thread ?
Greetings,
Vladimir NedevVantage developer, e-mail: vladimir.nedev@chaos.com , for licensing problems please contact : chaos.com/help
I'm having a similar issue but with Revit. Every time I have live link enabled and change something on a material, Revit freezes. Sometime a few seconds, but often for a few minutes. As soon as I close Vantage, instantly or a few seconds later Revit will unfreeze.
I'm using the latest Vantage (1.8.4) and V-Ray (6.00.21) versions, and Revit 2022.
I have two GPUs installed; a P2000 and a RTX 3060 (Driver versions 528.49).
I've tried different variations of what programs use what GPUs (using Nvidia Control Panel). My initial setup was Revit and Asset Editor use P2000, and all rendering programs (Vantage, V-Ray) use the 3060.
EDIT: This seemed to have fixed its self for now, so never mind I guess.Last edited by tracy_downs; 24-02-2023, 08:27 AM.
