HI,
I recently tried to make an animation with vantage1.8.4. I exported a vrscene with max and then read the file with vantage. Sometimes there was a local error in rendering the animation, I couldn't find the reason.
I tried to output the sequence frame and got the same result, still a partial error.
Does anyone else have the same problem as me? How can you avoid this problem?
Advice would be grateful.
Thank you
JING
Please note the coffee table section below, in the center of the image
Thank you
JING
