Material turns to black in random frames
  • Material turns to black in random frames
    Hi, I recently notice that some frames in my walkthrough seems to be missing some material and rendering the model in black, this happens when I open and render a walk through in a different PC. Attached image for reference.
    The process I did for this scene is as below:
    1. Prepare Chaos Vantage file in PC01
    2. Save Vantage file in server
    3. Open Vantage file in PC02 and render animation in PC02
    Has anyone encountered this before?
    1. Do the materials that turn black use an image sequence ?
    2. Are the textures being read from a network drive ?
    3. Is there anything in the log about not being able to load an image/texture ?
    Greetings,
    Vladimir Nedev
      Note that the .vantage file does not contain any assets such as mesh and texture files. You can see it's a very small file. The actual render data is contained in the .vrscene file and in external files it references. The render machine should have read access to all those files. You can check the Vantage log (Help->Open debug log) for asset file loading errors - there is a filter at the bottom.
      Nikola Goranov
      Chaos Developer
        Greetings,
        Vladimir Nedev
        Nope they do not use an image sequence, but I do notice that the settings under the vrayproxy (Proxy Params->Animation->Playback) is set to "Loop", I have changed them to "Still".
        Yes
        3. Is there anything in the log about not being able to load an image/texture ?​
        I am unable to reproduce the issue currently, will monitor and check if the issue resurfaces.
          Ok noted. I will check the log file if the issue resurfaces, unfortunately the log file doesnt show the records for a few days back.
