How many AA samples are you using ? Which version of Vantage ?
There are several options:
1. Increase the LC sample limit (e.g. from 256 to 2048 ). This might not be enough to fix the issue however.
The animated image sequence on the TV causes the light cache to be cleared each frame which causes it to change and flicker I think.
2. Disable the light cache and increase the number of AA samples to the largest value you can wait out.
I am experimenting with some render settings, but i find that if i increase too much, render time will explode and maybe makes it not worth it to use Vantage. And it doesn´t clean up all splotches, using, for example, 2000 samples.
Did you try turning off the light cache ?
Can you send us your scene, so we can test it ?
