Idle Live Link
  • Idle Live Link
    I am not sure what isn't working, but I am getting a idle live link. I am seeing a exporting node, with like an estimated 30 minutes export, and then idle. I never had this issue prior to 2.0.
    [20:28:20.003] Warning : Render host bobby (127.0.0.1:20701) is not responding
    [20:28:20.007] Warning : Server dropped and there are no more render hosts that can work on the scene. Waiting for a host to connect...
    [20:30:01.818] Warning : Render host bobby (127.0.0.1:20701) is not responding
    [20:30:01.821] Warning : Server dropped and there are no more render hosts that can work on the scene. Waiting for a host to connect...
    Bobby Parker
    www.bobby-parker.com
    e-mail: info@bobby-parker.com
    phone: 2188206812
    My current hardware setup:
    • Ryzen 9 5900x CPU
    • 128gb Vengeance RGB Pro RAM
    • NVIDIA GeForce RTX 4090 X2
    • ​Windows 11 Pro
    I sent it to render and I get this.
Name:	Screenshot 2023-07-03 203425.png
    Bobby Parker
    phone: 2188206812
    • Ryzen 9 5900x CPU
    • ​Windows 11 Pro
      Maybe some sort of firewall is preventing the connection ? Can you try disabling your firewall and test this way ?
      What's the status in the "Live Link" menu in Vantage - it should say "Status: listening on port 20701" ?
      Greetings,
      Vladimir Nedev
        MAX ended up going into not-responding. I let it sit all night and it never loaded into Vantage. I just tried a simple scene, and it worked. Maybe, I ran out of video memory of yesterday's model. However, I successfully rendered a much larger animation earlier in the week. If it happens again, I'll pay notice to the Vantage menu messages. Thank you.
        Bobby Parker
        phone: 2188206812
        • Ryzen 9 5900x CPU
        • ​Windows 11 Pro
          I tried a new project tonight and nothing is working. Prior 2.0 worked fine on similar projects. I got long export times, thing like 3hours. I'll restart and it'll say exporting done, but nothing happens in Vantage, and I have also gotten .net errors.
Name:	Screenshot 2023-07-05 195753.png
          Bobby Parker
          phone: 2188206812
          • Ryzen 9 5900x CPU
          • ​Windows 11 Pro
            Hi Bobby,
            Can you try downgrading to 1.8.6 and see if the problem persist or is it only reproducible with the 2.0 version?
            best regards,
            Alexander
            Alexander Atanasov
            V-Ray for Unreal & Chaos Vantage QA
            Chaos
              Same unknown system exception error with 1.8.6
              Bobby Parker
              phone: 2188206812
              • Ryzen 9 5900x CPU
              • ​Windows 11 Pro
                Could it be the video driver? I hate having to downgrade for a software.
                Bobby Parker
                phone: 2188206812
                • Ryzen 9 5900x CPU
                • ​Windows 11 Pro
                  It's almost certainly NOT the video driver.
                  Greetings,
                  Vladimir Nedev
                    If it is still happening in 1.8.6, when it worked before, then it may not be related to Vantage. Can you please send us a sample scene where its easily reporoducible?
                    Alexander
                    Alexander Atanasov
                    Chaos
                      I just ran an animation on a simple scene (just a gray-scale house) and it works fine. The odd thing is when V2 came out I rendered a heavy scene, heavier than the last two I tested, and it worked just fine. Something is causing the unknown error.
                      Bobby Parker
                      phone: 2188206812
                      • Ryzen 9 5900x CPU
                      • ​Windows 11 Pro
                        I turned off Forest Pack Pro and everything worked fine. I turned the grass back on, and my link broke. I relinked and it exported, but Vanatge didn't update. A lot of warnings, but no errors. I guess I shoud look into Chaos Scatter to see if things work better.
                        CPU 32%
                        Memory 65%
                        GPU 3%
                        Bobby Parker
                        phone: 2188206812
                        • Ryzen 9 5900x CPU
                        • ​Windows 11 Pro
                          CPU 32%
                          Memory 65%
                          GPU 3%
                          If you could send us this scene with the Forest Pro object, it will be very helpful.
                          Greetings,
                          Vladimir Nedev
                            Sure, I'll upload and post a link.
                            https://drive.google.com/file/d/1Rkg...ew?usp=sharing
                            Bobby Parker
                            phone: 2188206812
                            • Ryzen 9 5900x CPU
                            • ​Windows 11 Pro
                            • #15
                              Has anybody looked at this? I posted it five days ago.
                              Bobby Parker
                              phone: 2188206812
                              • Ryzen 9 5900x CPU
                              • ​Windows 11 Pro
