Vantage 2.0 3ds Max 2016 live link problem
  • Vantage 2.0 3ds Max 2016 live link problem
    Hello everyone,
    I'm having some issues with the live link between Vantage 2.0 and Max 2016.
    Can someone help me with this?
    As I remember last time we had to download the nightlies version.
    I'll try with first ; vray_adv_52024_max2016_x64_32168_install.zip
    and second; vray_adv_52024_max2016_x64_31541_install.zip​
      This is a very old Max version that I think V-Ray has not supported for a while (years). Have you successfully used it previously with Vantage?
      Nikola Goranov
      Chaos Developer
        Yes, this was possible with the Vantage version 1.8.3.
          I have box version 3ds Max 2016 installed at the company I work for, and they don't want to upgrade to a newer version (due to the subscription system and costs). Therefore, I have to continue using 3ds Max 2016 U4 with V-Ray 5 and Vantage 2.0 installed as vanilla.
            Nope, same errors.
              Could you try if the following prevents the error?
              - Install Vantage 1.8.3
              - Make a copy of the files in C:\Program Files\Chaos Group\Vantage\dcc_scripts\3dsMax
              - Install Vantage 2.0
              - Overwrite the files in the scripts directory with those from 1.8.3
              Nikola Goranov
              Chaos Developer
                I used version 1.8.3 and 1.8.6, but I'm still experiencing the same issue. This problem seems to have occurred primarily after formatting the computer and reinstalling all applications from scratch, including the latest V-Ray 5 installations for 3ds Max 2016.
                  I'm sorry, I'm not sure if you mean you used Vantage 1.8.3 or only the script files from 1.8.3 copied over the 2.0.0 install as I described. Actually does Vantage 1.8.3 work without the file copy hack? You said it worked before, but does it work now?
                  Nikola Goranov
                  Chaos Developer
                    Ah! I'm sorry. Unfortunately, the live link is not working for both versions of Vantage at the moment (it was working on the old system where I can't remember which version of V-Ray was installed, but now I have downloaded the latest V-Ray 5 for 3ds Max 2016 on the newly formatted system).
                    I haven't moved on to the folder hacking part yet
                      That is eight versions ago. You might have a good argument for your company to upgrade.
                      Bobby Parker
                      www.bobby-parker.com
                      e-mail: info@bobby-parker.com
                      phone: 2188206812
                      My current hardware setup:
                      • Ryzen 9 5900x CPU
                      • 128gb Vengeance RGB Pro RAM
                      • NVIDIA GeForce RTX 4090 X2
                      • ​Windows 11 Pro
                        Oh! You telling me
                          The issue still persists.
                            We don't have licenses for Max 2016 so we can't even try this :/
                            Nikola Goranov
                            Chaos Developer
                            • #15
                              Maybe remote support like remote desktop connection could be possible?
